🛠️ Ghost in the Gas Tank: What E20 Means for Non-Compliant Motorcycles
General Discussion
7 3 6.1k
    Brothers and sisters of the road — the fuel pump’s changing, and so is the brew we run our machines on. With E20 being already rolled out, the question is burning hotter than a flaming exhaust pipes:
    👉 Will this stuff hurt our old-school, non-compliant bikes?
    I’ve dug through research papers, lab studies, and real-world reports to lay down the facts — so we don’t have to rely on hearsay at the tea stalls.
    🔥 Quick Take (TL;DR for wrench-turners)
    Modern, fuel-injected machines built for ethanol blends? They’re handling E20 without breaking a sweat.
    Older, carburetted, two-stroke, and steel-tank rides? They’re staring down more risk — fuel lines swelling, carbs gumming up, tanks rusting, and mileage dropping.
    Riders are already reporting reduced fuel economy and hiccups on classics, even while officials and OEMs insist it’s “all good.”
    đź§Ş What the Studies Say
    Modern Fuelies: Controlled evaluations show E20 keeps performance almost the same as petrol, as long as the bike’s built with ethanol-proof parts.
    Small Engines & Oldies: Research flags leaner mixtures, corrosion, and lubrication issues in two-strokes and carb’d bikes. These motors don’t like their cocktail changed.
    Material Trouble: Ethanol attracts water, rusts steel, and eats rubber that isn’t ethanol-rated. That means cracked hoses, leaky petcocks, and gummed carbs.
    On the Streets: Reports from riders in E20 zones are already showing drop in mileage and old bikes choking after storage. Officials shrug it off — but the workshop bills tell another story.
    ⚠️ Red Flags for Old Rides
    Carburetors corroding, floats sticking, jets clogging.
    Rubber hoses swelling and cracking.
    Steel tanks picking up water → rust patches.
    Two-strokes suffering from lubrication shifts.
    Mileage drop and weaker pulls on throttle.
    🛠️ Garage Wisdom (Keep Your Machine Alive)
    Swap old hoses and seals for ethanol-rated replacements.
    Keep tanks full or bone-dry if storing — don’t leave half a tank to sweat. Add a stabilizer if parking the bike for months.
    Drain carbs if you won’t ride for a while.
    Watch for leaks, rough idle, fuel smell — catch issues early.
    Get jets cleaned and mixtures checked; lean burn can cook your piston.
    For two-strokes: double-check with mechanics before long runs on E20.
    🏍️ Why This Thread Matters
    Most lab tests are on shiny new cars, not our battle-scarred Bullets, Yezdis, RD350s, or two-stroke scooters. We’re the test bench now.
    Let’s use this thread as a logbook:
    Drop your bike’s make/model/year.
    Say if it’s carb or EFI, steel or plastic tank.
    Share what you’ve seen with E20 — mileage drops, hose cracks, carb troubles, or no issues at all.
    The more we pool, the stronger we ride.
    📚 Sources (for the nerds among us)
    SAE / systematic evaluation of E20 in modern vehicles.
    NREL global review on E20 drivability & compatibility.
    Minnesota small engine study — risks for carb’d and 2-strokes.
    Materials compatibility research — ethanol vs metals & rubbers.
    News on India’s E20 rollout and OEM/rider reactions.
    Bottom line: For the old warhorses in our garages, E20 isn’t just another pump number — it’s a ghost in the gas tank. Ride prepared, wrench smart, and let’s see how our machines fight back.
  • wrote on last edited by IBR_Kritik
    My observations:
    1. RE Himalayan 411 BS4 FI: cracked fuel pump case which resulted in fuel leakage. And recently I observed chocked fuel cap, Which can also be related with E20 since some fuel is boiled outside from fuel cap lock after full tank (411 owners can relate).
    2. Bajaj Pulsar 180 DTSi 2006 : Issues in cold starts, since it has carburetor thus more prone to E20 witchcraft.
  • IBR Admin
    I have come across few videos about fuel pump issues but still can not directly link it to the ethanol mix. Personally i have seen a dip in average on my versys 650.
    The E20 gunk that we see in our throttle bodies is'nt a pretty sight at all. I have also observed a lower mileage in my ride. Worst part is even premium fuels like Shell have 15% Ethanol blend!!.
    This Ghost is getting bigger and bigger thanks to Gadbadi ji. E85 and E100. Recently I watch a short of autocar comparing E20 and E85. here's link https://www.youtube.com/shorts/jLgjDkskhQY
    Detailed podcast comparing efficiency and costs: https://www.youtube.com/watch?v=1b1vov4oSAs
  • IBR Admin
    I have read somewhere that you need to be extra careful that not even a single drop of water enters the fuel tank containing Ethanol mixed fuel. When water enters a tank containing ethanol-blended petrol (like E10 or E20), it could create a serious mechanical hazard. Because ethanol is highly hygroscopic (water-attracting), it absorbs the water into the fuel mixture
  • I have read somewhere that you need to be extra careful that not even a single drop of water enters the fuel tank containing Ethanol mixed fuel. When water enters a tank containing ethanol-blended petrol (like E10 or E20), it could create a serious mechanical hazard. Because ethanol is highly hygroscopic (water-attracting), it absorbs the water into the fuel mixture
    @sajeesh Yes sir, and since water, having a higher density than petrol, separates and accumulates at the lowest point of the fuel tank due to gravity. Under low fuel conditions, when the fuel level approaches the reserve or near-empty state, the probability of water ingress into the fuel delivery system increases significantly. This occurs because the fuel pump intake is positioned near the bottom of the tank, from where it may draw the settled water along with the remaining fuel, potentially leading to engine misfiring, poor combustion, stalling or permanent damage to engine parts.
    Royal Enfield has already started rolling out E20 complaint carburetors (for obviously older carburetor models) not sure how it works.
    If anyone has more info or updates, please do share here.
  • Ride Plan 2nd October to 4th October
    General Discussion
    srini2609S
    Ride Start Date:-02-10-2026 Flagoff Point:- Bus stand Opposite Akshardham Temple. Assemble Time:-4.45 AM Ride Starts:-5.00AM First Stop for Breakfast:- As Usual 110 Kms away Tadka Things to carry: DOCUMENTS: (Mandatory ) • RC book/card • Driving License • Bike Insurance • PUC RIDING GEARS: • Full face helmet • Riding Jacket or Any thick jacket with elbow guards • Riding pants or Jeans with knee guards • Riding gloves • Riding Boots/High Ankle boots (NO SPORTS SHOES/Casual shoes) • Rain gear Optional Carry your own Herbal Decoctions and tubular smoking rolls.
  • Trying to contact Akash Singh Patna
    General Discussion
  • Batalik Calling! 🏔️ | Sep 2026
    General Discussion
  • 2026 Mega Adventure Bangalore
    Moved General Discussion
    @needanusername u can park at aabhas house at Chattisgarh at Ambikapur.. ranchi wud b 3 ton4 hours from there
  • Happy Birthday IBR - You turned 18 today
    General Discussion
    10
    5 Votes
    LonewolfL
    18 years… and what a ride it’s been. From the first few riders who dared to dream, to the countless brothers who joined along the way — respect to every soul who built this legacy and to everyone who keeps it alive today. Ride safe, ride proud, and keep the spirit burning. Ride On, always. Eighteen years of roaring engines, sunrise starts, midnight highways, endless laughter, breakdown moments, chai stops, and bonds that turned strangers into family. This isn’t just a milestone — it’s a celebration of every heartbeat that thumps in sync with ours. Heartfelt congratulations to the entire IBR family. Here’s to the memories made, the stories written on the road, and the unshakeable brotherhood that only grows stronger with time. Proud, grateful, and blessed to be part of this journey. Keep thumping, brothers — the road ahead is ours.
