Need Reviews and Suggestions on Scram 440
Views and Reviews
30 16 7.8k 3
  • Hey Brothers,
    Does anyone across any chapter, owns the Scram 440? If one, please share your genuine feedback and reviews.
    Currently the Delivery of 440 is on hold, but hope soon it'll start.
  • 440 , Hero ?
  • 440 , Hero ?
    @dvt.akash
    Forgot to write Scram 440
  • Why Scram 440?
  • Didn't they recall this model for engine issues?
  • Scram is off the shelf. Not even available on RE website under their offerings. Himalayan is 10 times better deal.
  • https://www.royalenfield.com/in/en/motorcycles/scram-440/
    Available on website now.
    Probably preferred because of the seat height ratio.
    @Chiraac too is exploring Scram option
  • My bad... i didn't realize its still there.
  • Jis din haldar lega mei ek helmet Gift doonga Studds ya steel bird ka😂
    @srini2609
    Extra visor ke paise muzhese lena
    @srini2609 said in Need Reviews and Suggestions on Scram 440:
    Gift
    SMK ka chahiye Sri sir
  • Hey Brothers,
    @amithaldhar @Chiraac can give more info, as he recently purchased one and has been doing great rides on this new machine
  • Hi @amithaldhar I think I can now give the reviews on the Scram 440 having completed almost 3000kms:
    Pickup: Moving on from TB350 the pickup of 440 is fabulous, it just flies with a simple rev. I have touched 110 and trust you me the vibration as bare minimum as compared to TB350.
    Braking: IS very smooth, the ABS kick in easily.
    Headlamps: They are a disaster; you will have install fog lamps for clear vision at night. The lights are of no use.
    Seating posture: You will have to adjust and adapt from the relaxing posture of TB350 to the aggressive stance of 440, but the transition will only come after a few hundred kms.
    Weight Balance: Surprisingly both the TB350 and 440 have the same weight but the 440 feels lights and the weight balance is just perfect.
    First Service Cost: it costed me around 950 for the first service and you might have to check on your brake pad regularly as with the boots and the way we have been riding the TB350 we tend to rest our foot on the brakes of the Scram 440. Brake pads were 350 Rs. Also, when you go for your first service, they will change the magneto coil by themselves (its better you remind them) free of cost and use some gadgets to tune it up so the first service will a little longer. Please make sure you check with the service center if they have the magneto coil available and accordingly book your slot.
    These are my observations so far.
  • @Chiraac
    You forgot to mention "Ghungroo" wala issue..
  • @Chiraac
    @TheOne
    Yes did forgot to mention that on purpose, @amithaldhar apne ghungroo adjust karna padta hai time to time 🤣
  • @TheOne
    @Chiraac ! Waise Ghungroo tp Metal ke hote hai ..... 😉
    You mean Ye wala Ghungroo Kya 🤪
    @Chiraac Thanks Bhai for the detailed review 🙌🙌 it's pretty eye opening and the Ghungroo seth wala too.... Woh to TBTS mein bhi set karna padta hai 🤣 agar frenchie na ho to 🤣🤣
    By the way, the new lots are coming with the sorted issue of Magneto coil, do they still change it in the service?
    @Chiraac said in Need Reviews and Suggestions on Scram 440:
  • @Chiraac Thanks Bhai for the detailed review 🙌🙌 it's pretty eye opening and the Ghungroo seth wala too.... Woh to TBTS mein bhi set karna padta hai 🤣 agar frenchie na ho to 🤣🤣
    @amithaldhar yes new lot mien change hoke aata hai coil but it would good to check with the service centre if they can find it out for you.
  • @amithaldhar Bhai utha le!
  • @amithaldhar
    Utha liya ke abhi bhi Ghumgroo adjust kar raha hai.. 🤪
  • BluArmor C50 Review
    Moved Views and Reviews
    9
    7k Views
    sajeeshS
    I think few of the Bangalore members are buying the Sena devices for their upcoming MA. Hope they find this message and help you out.@SudhirNanjappa , @sridhar.pradeep
    Jatinvr46J
    this one is a power packed roadster, which looks like a quasi scrambler, although not recommended for Touring, it's a great fun machine for the sprints around town and short rides, hopefully one day R.E thinks of a touring version with a bigger tank and wind screens. Downsides turning radius Splash protection during wet road conditions. Upsides It'll put a smile on your face every time you twist it open
    6k Views
    Point where the crash guard is fixed is the same point where Engine is bolted to the chassis. So incase of crash this point probably takes the brunt and hence possibilities of chassis getting damaged. In her case, aftermarket nut used probably were not of good grade. Also her crash guard do not seem to be genuine as RE OGs do no have sliders on them. [image: Mount.jpg]
